Aeriel
Aeriel
Postby caddyboy » Wed Feb 13, 2013 6:14 pm
My van came with the aeriel missing, all that is left is the base and a small stud coming out of it.
Can I remove the stud to fit an aftermarket one or is the stud a permanent fixture in the base? I've tried two which were lying in a mates garage but neither of them fitted.
What have you guys done??
caddyboy
Re: Aeriel
Postby gt_addict » Wed Feb 13, 2013 6:49 pm
You should be able to take the base off the roof by undoing the bolt under te headlining in the cab. I suppose you could fit what you wanted to it after that. Or just drop into a scrappy and get one off another ford.
gt_addict
Re: Aeriel
Postby caddyboy » Wed Feb 13, 2013 6:52 pm
I was mainly wondering if the actual stud comes out the base or is it fixed permanently to the base?
caddyboy
Re: Aeriel
Postby topmanuk » Wed Feb 13, 2013 10:24 pm
I have just looked at an old base I have and no mate it will not come out
topmanuk
Re: Aeriel
Postby caddyboy » Wed Feb 13, 2013 10:50 pm
so looks like a trip to the scrapyard for a proper Ford one or a trip to the dealer probs with a 2nd mortgage! Cheers for the info,
caddyboy
Re: Aeriel
Postby Mylee » Wed Feb 13, 2013 11:31 pm
Remove the interior cab light and unbolt the base unit. Cable to the stereo is separate. You can buy a new base and whip ariel individually from your stealer. IIRC the base is under £20
Mylee
Re: Aeriel
Postby caddyboy » Wed Feb 13, 2013 11:37 pm
Cool, cheers.
caddyboy
