NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Fri Apr 05, 2013 5:02 pm
2004 Transit Connect T200 LX
This is when I first got it.
Rear bumper look new :D
Still has the original Roof insulation, although it could do with cleaning up.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Fri Apr 05, 2013 5:04 pm
17" wheel obtain from ebay for £125 :D
Now fitted
Also fitted Connect sportvan seats
Rear N/S door replaced for a later one, perfect colour match no need to respray it. :D
paul2012
Postby paul2012 » Fri Apr 05, 2013 5:07 pm
2009 onwards genuine Ford front bumper
Platinum front upper grille
front steel slam panel to replace the plastic one currently fitted to my connect.
paul2012
Postby paul2012 » Fri Apr 05, 2013 5:10 pm
Front end strip down to fit replacement slam panel
panel fitted
Headlamps & new bonnet lock refitted
Now waiting for my new front bumper to be painted up :D
paul2012
Postby paul2012 » Fri Apr 05, 2013 5:15 pm
New complete dash, bargain at £125 removed from a 2010 connect.
Old dash in process of being removed
New dash support fitted
new dash fitted
Looks better with new dash :D
paul2012
Postby paul2012 » Fri Apr 05, 2013 5:23 pm
Old hand brake lever to be replaced is in wrong position
New one fitted
New parts to fit floor rear section of centre console
New column switch gear removed from 2010 connect along with steering column
Switch gear & steering column now fitted
New Focus mk3 leather steering wheel fitted.
paul2012
Postby paul2012 » Fri Apr 05, 2013 5:26 pm
New dash is fully wired up, just require to get speedo working.
Next job is to fit ABS brakes, As this is what generates the vehicle speed signal for tne instrument cluster. (Ford decided to lose the VSS sensor on the gearbox from 2006 onwards)
I already have a spare rear disc brake ABS axle & grabbed this lot at a bargain price of £60 :D
very easy to fit :wink:
paul2012
Postby kjb » Fri Apr 05, 2013 5:50 pm
please don't take offence,but I feel I have to ask why go to this trouble,could you have not bought a newer model connect,given that you have had to source all the parts,if you had to factor in labour this would surely not be worth doing.May confuse the buyer if ever you sell the van
kjb
Postby paul2012 » Fri Apr 05, 2013 6:09 pm
None taken :wink:
At the current price I have paid so far is less £1500 - including price of van, which is alot less than the current new shape :D
All the work/labour is done myself so no costs there. As for getting bumpers etc painted I get my brother to do that at his workplace for free 8) (I supply the 2k paint)
As for parts they are readily available.
You could say the same when members fit mk2 front bumpers etc on mk1 connects when they could buy a later one :?:
Some of us on here enjoy customising/modifying our vehicles, & if anyone is thinking on doing the same. I am showing it can be done.
paul2012
Postby Mylee » Fri Apr 05, 2013 6:53 pm
Really can't understand why you feel the need to post all this again. 99% of people on here have seen this tread and pictures before.
Mylee
Postby electric » Fri Apr 05, 2013 8:20 pm
Mylee wrote:Really can't understand why you feel the need to post all this again. 99% of people on here have seen this tread and pictures before.
There's new members joining all the time,if you don't want to read it all again then don't click on the link.
2005 T220 LX TDCi Rolling on 18 inch Jaguar alloys
http://www.acornautoservices.co.uk
Servicing and Repairs, MOT testing, A/C systems regassed
electric
Postby kjb » Fri Apr 05, 2013 8:41 pm
Respect given,helluva a lot of work,look forward to seeing the finished van :D
kjb
Postby zaxis210 » Fri Apr 05, 2013 8:56 pm
great job you doing there m8 will be a good van
zaxis210
Postby g-man » Fri Apr 05, 2013 9:06 pm
when you've been on here quite a bit you sometimes forget that.......i'm often guilty of that and don't normally say owt unless its double posting
g-man
Postby tez » Sun Apr 07, 2013 7:24 pm
just hope when u finished it all with mods and for the price off the van as u said a bit bk u where keeping all the bills and see how much u spent on it so far would love to no when its all done how much it has cost ya to do it all up 8) 8) 8)
tez
