Cheapest way to get a spare key and fob.
Postby LeeH » Mon Jul 29, 2013 10:01 am
Any tips would be appreciated!!
Cheers.
Sent from my iPhone using Tapatalk 2
LeeH
Re: Cheapest way to get a spare key and fob.
Postby millertime_1985 » Mon Jul 29, 2013 9:28 pm
I don't know about the fob...
But I got a spare key for my TC cut at Timpsons... key was cut and programmed in less than 10 mins. Cant remember the cost... but it was very convenient and probably cheaper than going to ford.
http://www.timpson.co.uk/services/66/no ... e-car-keys
Its Not a Van..... Its a Transit
millertime_1985
Postby Graham Taylor » Mon Jul 29, 2013 10:44 pm
Got my spare fob off ebay then had a key cut at local shop.
Graham Taylor
Postby LeeH » Tue Jul 30, 2013 1:04 pm
Great, is the remote easy to programme?
LeeH
Postby gt_addict » Tue Jul 30, 2013 1:14 pm
Yep, it's te key in the ignition turn it to position 2 and off 8 times or ten times then the locks cycle, then you have to press a button on each fob you wish to program.
It's something along those lines, someone will be a bit more specific soon :lol:
gt_addict
Postby Graham Taylor » Tue Jul 30, 2013 1:16 pm
Instruction usually come with the fob but if not:
Switch ignition from position 1 to 2, 8 times, locks will then lock & un-lock.
Press any button on remote, locks will then lock & un-lock.
Switch ignition to position 2, then completely off and remove key and test.
Graham Taylor
Postby millertime_1985 » Tue Jul 30, 2013 1:32 pm
gt_addict wrote:Yep, it's te key in the ignition turn it to position 2 and off 8 times or ten times then the locks cycle, then you have to press a button on each fob you wish to program.
Is that with any key...?
Last time I rear anything about self programming keys or fobs (back when I had my mk5) it involved using the red key... but that was a good number of years ago, so forgive me if I'm out of date with my understanding
millertime_1985
Postby sparkieno1 » Tue Jul 30, 2013 1:39 pm
doing the above will only do the central locking. this wont programme the chip for the immobiliser so you will be unable to start the van
sparkieno1
Postby LeeH » Tue Jul 30, 2013 3:13 pm
So how do you programme if for the immobiliser?
Thanks for your replies.
LeeH
Postby Marty.H » Tue Jul 30, 2013 6:01 pm
This may be of use.
viewtopic.php?f=54&t=116173
Marty.H
Postby LeeH » Tue Jul 30, 2013 7:53 pm
Thanks.
LeeH
Postby Cjm180 » Mon Aug 19, 2013 5:27 pm
might be a silly question, but will these keys start the van, with the immobilser and that??
Cjm180
Postby paul2012 » Mon Aug 19, 2013 6:24 pm
If you don't have 2 original keys that are required to program a third for immobiliser.
There is a very simple solution/mod you can do
Get hold of one of these keys - yes they can be reprogrammed for remote central locking on connects :wink:
On your ignition key, you will find a blue cap on the end - very carefully remove this to remove the immobiliser chip
This is immobiliser chip - be careful as its in a glass capsule :!:
Open up the new remote fob & fit your immobilser chip into it.
finally get a new keyblade cut, job done now you can start your connect :D
This is what I use for my connect - flip key remote fob 8) , Also used on Mondeo mk4, Focus mk2 etc.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Rusbus » Tue Aug 20, 2013 12:40 pm
So I take it if I buy a blank key off eBay I won't be able to get an immobiliser chip unless I go to ford?
Rusbus
Postby tez » Tue Aug 20, 2013 12:46 pm
so what about this one is this 1 be ok as well ?http://www.ebay.co.uk/itm/FORD-Transit-Transit-Connect-CONVERSION-SET-Folding-Key-and-FOB-in-One-/171065420530?pt=UK_Car_Accessories_Safety_Security&hash=item27d44b2af2 :?:
tez
