**FORD TRANSIT CONNECT ALTERNATOR WIRING **
Postby easyclean windows » Sat Mar 03, 2007 5:22 pm
Hi people i would liek to ask any off you if you haev a transit connect about the wiring for the alternator.
I need to find the no charge light as i am fitting a slit charge reay.
Apart from the main red battery cable and a small grey wire which i have disconnected and the engine doset start ,are only 3 other wires a blue,grey,and red.I have disconected but the battery light still comes on and off as normal so i was wondering if any of you knew which one it is as i have disconnected the ones i have but the charge light only comes on and off as normal?
thanks
easyclean windows
Postby stevo » Sat Mar 03, 2007 5:30 pm
There aint much info on here about the Connect mate.
I think only a few people actually own them too as they arent regarded as a "proper" Transit.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby easyclean windows » Sat Mar 03, 2007 5:58 pm
Not a real transit lol i used to have "a real" one see my posts but have a connect now as a "real one" i dont require the space and is that a piss take the focus forum?
easyclean windows
Postby davek » Sat Mar 03, 2007 8:07 pm
It's got "smart charge" so the light is switched by the pcm (engine brain) you'll have to a smart type relay that switchs at charging voltage
This is £11.25 from http://www.towsure.co.uk
Self-Switching Combination Relay
H78
The self-switching combination relay is straightforward to fit and supplies power to the caravan's +12v, battery charging and refrigerator supplies only when the vehicles engine is running and the alternator is providing enough output. It automatically prioritises charging of the vehicle battery over all other functions, and requires no connection into the vehicle's alternator or ECU wiring
davek
Postby motorwise » Sat Mar 03, 2007 10:34 pm
davek wrote:It's got "smart charge" so the light is switched by the pcm (engine brain) you'll have to a smart type relay that switchs at charging voltage
H78
spot on mate - saved me the trouble :D
connect is a cracking van by the way - got a ford badge (and it says transit on the back) so thats good enough for me
http://www.motorwise.net
motorwise
