Backbone of Britain wrote:iank10 wrote:hi paul
replied to your message can you confirm you received message as it remaims in the outbox
It will stay in the outbox until he has read the message
Ho, wasnt to sure
cheers for that
iank10 wrote:Backbone of Britain wrote:iank10 wrote:hi paul
Ho, wasnt to sure
cheers for that
paul2012 wrote:iank10 wrote:hi paul
I have just PM'ed you a link to where you can download the patch to enable module programming
paul2012 wrote:liteace wrote:
Connects use a calibration file when adapting\removing the speed limiter, you will have to re- do the cluster to ecu once done, you will need both keys to reprogram as well, when you choose speed limiter off it will come up with a message about a configuration file needed.
beats wrote:
