shudder vibrations under load
Postby ginsters » Sun Aug 10, 2014 8:44 am
looking for a bit of wisdom
fitted the new engine in the red van about 8 weeks ago and all been going well few gremlins here and there but seems to have developed a shudder from around 2000 revs and by the time its at 4500 it feel like its about to jump into a black hole!
checked the drive shafts and tyres and nothing else seems to be loose, ive a spare gearbox clutch and flywheel that i could fit but would rather not right now
any other ideas??
Thanks 8)
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
Re: shudder vibrations under load
Postby Dewhurst » Sun Aug 10, 2014 12:35 pm
Ive got exactly the same thing going on, I did notice a clip had come off on the fuel tank shield and it was bouncing around, im pretty convinced thats whats causing the issue, will get around to sorting it at some point, might be something worth looking at
Dewhurst
Postby paul2012 » Sun Aug 10, 2014 6:58 pm
MIne has started to shudder/vibratrion, more noticeable when pulling off & can be felt through steering column.
Not present when cruising at 60...
I suspect worn inner CV joint on O/S driveshaft as there is play in it - Halfshaft bearing is fine.
So new shaft on order (J&R)..
Also may have worn O/S front wheel bearing so will get that done at the same time.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby mrtn » Sun Aug 10, 2014 7:18 pm
Check the motor/transmission mounts. I had a broken trans mount and the engine was floating freely under the bonnet.
1.6 Ecoboost A/T LWB '16
mrtn
Postby gt_addict » Sun Aug 10, 2014 7:49 pm
Didn't you fit new shafts to yours from J&R when you put the new engine in Paul?
gt_addict
Postby paul2012 » Sun Aug 10, 2014 9:11 pm
gt_addict wrote:Didn't you fit new shafts to yours from J&R when you put the new engine in Paul?
Fitted a new N/S shaft from J&R as inner CV boot was split & was quicker just to change out the shaft.
I used the original O/S one, at the time appeared to be ok.
paul2012
Postby ginsters » Mon Aug 11, 2014 7:02 am
i think the mount under the battery was suspect when i fitted the engine,i will check that today!top call!
53 plate 75ps lwb
ginsters
Postby gt_addict » Mon Aug 11, 2014 8:44 am
How donyou check the engine mounts? (The two big ones either side)
gt_addict
Postby mrtn » Mon Aug 11, 2014 9:51 am
Visually by yanking the engine with a help from a rod for some leverage. Don't break anything! :idea:
There were some guidelines how much the engine may move measured from the valve cover, but I can't recall.
mrtn
Postby gt_addict » Mon Aug 11, 2014 11:14 am
So anything other than a little wiggle then :lol:
gt_addict
