paul2012 wrote:2009 is the change over year on Connects.
Depending on what version you have :-
2003-2009 Indicator/Hazard relay is located behind heater control panel on the right. Secured to main dash support.
2009-2013 Dash & electrics is completely different to the earlier Connects - There is NO indicator/hazard relay - indicators are control via GEM module instead
Post up a pic of you dash
liteace wrote:You have the later type, fitting tow bar electrics on this model requires one of these :
http://uk-trailer-parts.co.uk/7-way-uni ... ng-diagram
liteace wrote:I take it you've checked ALL fuses, if all good theres a poss chance you've damaged the GEM with the extra load from the trailer lights
farriervan2390 wrote:liteace wrote:I take it you've checked ALL fuses, if all good theres a poss chance you've damaged the GEM with the extra load from the trailer lights
I've been through all the fuses and all seem good , this gem unit, is it like a body control module or different. I've been told that the relay I think I've bust could not exist and be part of this gem unit?? There is normally an audible clicking like that of a relay from the indicators does that not suggest the presence of a relay? And where is this gem unit located
Cheers for the help james
liteace wrote:farriervan2390 wrote:liteace wrote:I take it you've checked ALL fuses, if all good theres a poss chance you've damaged the GEM with the extra load from the trailer lights
Yep GEM is like body control module on others, it sits up in the left hand side, just to the left of the clutch pedal, the audible clicking is the dash clock pod sounding like a relay
paul2012 wrote:If you've blow GEM module then central locking, wipers, headlights etc wouldn't work as well.
It's located behind fuse/relay panel on N/S (behind glove box)
Most likely blown a fuse.
Check fuse F130 15A
PS - GEM module do require to be programmed to vehicle. This is due to difference in vehicle spec - IE auto wipe/lights, Alarm, heated screen etc etc
