paul2012 wrote:2009 is the change over year on Connects.
Depending on what version you have :-
2003-2009 Indicator/Hazard relay is located behind heater control panel on the right. Secured to main dash support.
2009-2013 Dash & electrics is completely different to the earlier Connects - There is NO indicator/hazard relay - indicators are control via GEM module instead
Post up a pic of you dash
Hi, I’ve got a 54 plate connect, so from the description above if I’m sat in drivers seat the relay will be down to my left behind the heater dials? Ive found a relay behind the dash panel that is to the right of the heater switches that controls the heater controls. Any ideas?
