04 Connect wiper issue
Postby PaudieG60 » Tue Aug 04, 2015 1:46 pm
I have an ongoing issue with the wipers.
The issue I'm having is that sometimes my wipers do not work at all unless I flick the stalk to the fastest speed.
I can hear the relay clicking on the other speeds but nothing happens.
Is this a common issue?
Is it a simple case of just fitting a new relay?
PaudieG60
Re: 04 Connect wiper issue
Postby Graham Taylor » Tue Aug 04, 2015 4:43 pm
Replacement relays are cheap and easy to fit so would be a good starting point.
Graham Taylor
Postby PaudieG60 » Tue Aug 04, 2015 6:44 pm
Was thinking the same, I'll pick one up tomorrow and report back
PaudieG60
Postby PaudieG60 » Wed Aug 05, 2015 11:42 am
Does anyone have the part number for the wiper relay?
All 4 relays at the back of the glove box are clicking so I don't know what one to replace.
PaudieG60
Postby Graham Taylor » Wed Aug 05, 2015 1:03 pm
Graham Taylor
Postby PaudieG60 » Wed Aug 05, 2015 2:07 pm
Thanks for the links Graham!
New enough to tapatalk and didn't find those posts when I went to look for solutions to my issue
PaudieG60
Postby paul2012 » Wed Aug 05, 2015 3:10 pm
If wiper relay is ok.
Then fault possibly be..
1. Column wiper switch itself
2. Instrument Cluster
3. Wiring
Here is wiring diagram
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby PaudieG60 » Wed Aug 05, 2015 3:13 pm
Thanks Paul, I'll look into those options after I get a relay.
Will a universal relay from a motor factors do or will it have to be a Ford part does anyone know?
PaudieG60
Postby paul2012 » Wed Aug 05, 2015 3:33 pm
PaudieG60 wrote:Thanks Paul, I'll look into those options after I get a relay.
Get a proper Ford one.
http://www.ebay.co.uk/itm/FORD-FOCUS-FI ... 1a03f0a330
paul2012
Postby PaudieG60 » Wed Aug 05, 2015 3:38 pm
Will do!! Thanks for the pic and part#
PaudieG60
Postby PaudieG60 » Sun Aug 09, 2015 9:00 am
After taking the relay out to double check the p/n, there has been no issue sense refitting!
Relay was possibly loose and causing my issues.
PaudieG60
