ecu swap 75ps to 90 or even 115 tddi
Postby cyrus883 » Fri Aug 19, 2016 10:55 pm
can this be done ??? I have IDS or could I get a calibration code and do it that way ??? as 75ps omg lol :cry: hills :cry: thanks all steve :D
cyrus883
Re: ecu swap 75ps to 90 or even 115 tddi
Postby cyrus883 » Thu Aug 25, 2016 6:20 pm
:D :D well that's was helpful lol what is the best ecu to go for from a focus tddi or does it not matter thanks all
cyrus883
Postby Altransit » Thu Aug 25, 2016 7:52 pm
If you do a search, you'll find it's been done before. Fit a 90ps Focus TDDi ECU to a 75ps TDDi Connect, and code it in, and you'll have a 90ps Connect.
Check out the posts of Paul2012, he's done it a few times
Postby paul2012 » Sat Aug 27, 2016 4:19 pm
Yes easily done. 2 options.
1. Obtain a PCM from a Mki Focus 1.8 TDDI 90ps. Fit it program your ignition key to it then program connects fuel pump. Job done. run at 90ps.
2. Using IDS to install Focus 1.8 TDDI 90ps calibration onto Connects PCM. You'll have to trick IDS into thinking PCM is blank 1st before typing in Focus PCM & Calibration no in.
By doing it this way you don't need to program fuel pump 8)
PS Focus mk1 115ps is TDCI. Won't work on TDDI's :idea:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby cyrus883 » Sat Aug 27, 2016 4:40 pm
Thanks Paul was hoping ud comment would you know where to find the calibration number on a focus plz
cyrus883
Postby GDBxNS » Thu Jan 06, 2022 9:44 pm
paul2012 wrote:Yes easily done. 2 options.
@paul2012 I have ford focus mk1 1.8tddi 75ps. If I swap the ECU from 90ps one. Do I need to program the fuel pump too?
Is there any other difference between 75ps and 90ps except the ECU?
GDBxNS
Postby paul2012 » Tue Feb 08, 2022 9:38 pm
Focus mk1
1.8 TDDI are 90ps.
1.8 TDCI 100ps (equipped with VNT turbo)
1.8 TDCI 115ps (equipped with VNT turbo)
Connect
1.8 TDDI are 75ps.
1.8 TDCI up to 2006 are 90ps
1.8 TDCI from 2006-2013 are 75ps, 90ps & 110ps (110ps are equipped with VNT turbo)
paul2012
Postby GDBxNS » Thu Mar 03, 2022 5:39 pm
Focus mk1
1.8 TDDI are 90ps.
Connect
1.8 TDDI are 75ps.
@paul2012 No, I have 1.8 tddi 55kw, 75ps focus mk1, they are rear but exist. You can google it.
(I'm not from UK.)
And I'm curious
1) if I swap the ECU from 90ps one. Do I need to program the fuel pump too?
2) Is there any other difference between 75ps and 90ps except the ECU?
GDBxNS
Postby saxotrans » Sun Aug 04, 2024 5:35 pm
Hi Please can Paul from Wretton please contact me regarding a transit repair. I live in Upwell
saxotrans
