Connect questions?
Connect questions?
Postby grandgu » Sat Jun 30, 2007 3:06 pm
Hi just new and although there is a conflict about this being a 'true Transit' I hope the questions are easy enought to answer.
The van came with only one key, and immobliser, can I get a copy easy enough, or is this going to come to money! I had a estate last year and only one key, when in France locked the key inside and had to break a window to get in, had a copy made but this only opened the doors did not start the car.
I have read some messages about keys immo's etc but have a conflict in the brain! easy one please?
Thanks GG
grandgu
Postby 100 T280 » Sat Jun 30, 2007 5:19 pm
Presuming your remaining key has a blue chip (blue insert in the plastic part of the key) you can get them copied cheaply enough. You then just program the new keys, or for better security, de-program the existing key, then re-program it along with the new one(s). Instructions will likely be on here somewhere.
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby Nighthawk » Sun Jul 01, 2007 8:47 pm
Connect does have the blue dot key, so as long as you get a key with the correct chip inside a dealer will be able to add it for you.
The vehicle requires an "in code" from FMC to gain access into PATS so without a second coded key being with the vehicle, you can't add a further key yourself.
Transit.........Job done
Nighthawk
Postby 100 T280 » Sun Jul 01, 2007 8:53 pm
Yes, I forgot you need two existing keys to be able to do it... :oops: :oops:
100 T280
Postby grandgu » Mon Jul 02, 2007 2:00 pm
Ok Thanks. Any idea what a spare one would cost from a dealer?
grandgu
