Ive just changed the master cylinder on mine (2004 connect) as the pedal went floppy and i had to bleed every few months so wanted to do a permanent fix.
I am now stuck with the pedal to the floor even after bleeding (gunsen easy bleeder)
Whats strange is we tried running the easy bleeder with no fluid in the bottle and nothing came out of the bleed nipple, nor did the fluid drop from the reservoir?
