Leaf Springs
Leaf Springs
Postby seagullsandvikings » Sat Apr 28, 2018 11:56 am
Hi all.
I have a 2011 T230 which has a visibly damaged leaf on the RIGHT side, as a result that arch sits more than an inch lower than the other side when empty.
The steering wheel and front road wheels all turn to the left when i drive forwards, and to the right when i reverse. The tracking is fine as are all of the front suspension components, tyre pressures and brakes etc.
I will be converting the van into a campervan so it will never have any significant load in the back.
I have a few questions:
Do you agree that the steering issues are likely being caused by the defective leaf ?
Can i replace the leaf springs on both sides with T200 ones (SWB on LWB), will they fit ?
How will handling be affected if i replace the springs with T200 ones ?
Many Thanks
seagullsandvikings
Re: Leaf Springs
Postby paul2012 » Sat Apr 28, 2018 7:10 pm
Welcome to the forum. :wink:
Fit correct rear springs to your Connect T230 (LWB)
Connect T200 (SWB) have lower GVW rating :!:
**NOTE**
There are 2 types available
1. Single leaf
2. Double Leaf
2004 Jeep Grand Cherokee LTD 2.7
2003 Jaguar X-Type 2.1 V6
2001 BMW Mini Cooper 1.6
2015 Vauxhall Astra Tech Line GT 2.0 CDTI 165ps
Ford IDS services
SUBCRIBE YouTube channel https://www.youtube.com/channel/UCoEIqO ... 3qiAsAq_8w
paul2012
Re: Leaf Springs
Postby Kenton » Sat Apr 28, 2018 8:05 pm
As Paul said! And speak to a good leaf spring specialist if you don't fancy ford prices. And they will contour the new one to exactly suit the other. They should also give you a health check on the other side too.
Connect 05 T230 LX 90 LWB
ST 17" alloys & Toyo Proxes
Focus ST170 seats
Fiesta Zetec steering wheel & G/K
Mondeo Door handles & vents
C/F Bonnet wrap
Side bars
Facelift rear lights
Fully lined & carpeted
K&N Panel filter
Lowered
Kenton
