Mileage correction
Mileage correction
Postby Scorcha » Thu May 03, 2018 12:17 pm
My van has done 140000 but just before i bought it the cluster was changed to one which only had 113000 due to a faulty cluster. Anyone know how i can go about getting mileage correction done or anyone offering the service in Essex or Kent? Its a 2005 Transit Connect
Scorcha
Re: Mileage correction
Postby pestguard1 » Mon Oct 22, 2018 10:57 am
any milage correction is illegal I`m lead to belive
pestguard1
Postby doebag » Mon Oct 22, 2018 2:51 pm
Not quite, if it is done to deceive, then yes. If it is documented in the service history then perfectly ok.
To the OP, did the seller make a note on the paperwork, possibly on the MOT cert after the replacement was fitted.?
doebag
Postby Altransit » Mon Oct 22, 2018 6:40 pm
Vantuner did mine :)
It's perfectly OK to increase the mileage whatever the reason, and it's OK to decrease if you're retrofitting a higher mileage speedo, but decreasing it purely to deceive, is illegal.
The MOT history will dob you in if you're up to no good, anyway :P
Postby Scorcha » Mon Oct 22, 2018 6:58 pm
Altransit wrote:Vantuner did mine :)
Where is Vantuner based?
Scorcha
Postby blue estate » Mon Oct 22, 2018 7:46 pm
West Ruislip
mk2.5 Focus zetec 1.8tdci 09 hatch
My other car is a 44t MAN TGX 480 tractor unit
blue estate
