Can anyone tell me if the the front hub from a T200 connect is the same as the T230 connect?
Basically I've got the hub complete with bearings etc from a T200 that I wont to fit to my T230 as I don't have a press to press new bearings into the original hub.
I know the 200 is designed to take a lower weight than my 230 however from the little I know about it all the engine & gearbox etc is the same through the models so I thinking it should be the same hub & bearing etc.
Any help or information would be great so I don't spend my time pulling my van to bits just to find out the T200 hub / bearing doesn't fit the T230 drive shaft etc
Many thanks
