Hi Guys, i'm new but loving the forum, so much info! I have searched for my particular issue but couldn't find anything relating to the connect, only the bigger Transits.
I Have very recently acquired a 2014 Plate Mk2 L2 240 1.6 TDCI 95s model that in time i intend to kit out as a mini campervan. I bought it as salvage repairable (Cat S) having only done 17,000 miles, i'm not overly bothered about resale value as to be honest i have every intention to use it for a long time, or at least until i'm over my midlife crisis! With it being a front corner shunt i will need to fit a new wing, headlight and front panel and have slight damage to the bonnet repaired. 1st off can anyone recommend anywhere to buy said parts, not overly bothered about them being aftermarket ones.
And secondly and the main reason for posting, the drivers airbag has gone and presumably the seatbelt prestensioner so i'll need new(or from a donor van) but my question is will i also need a new crash sensor and if so where are they located? behind front bumper? I will obviously need the ecu clearing of crash data but having looked on t'interweb it only costs £25 if you send it away.
Eddy
