Morning all,
So , you will be pleased to know I didn't change the coil pack whilst the engine was running
I am quite chuffed that I have managed to do this without taking to the garage, to be fair it is pretty easy to do even for me
I have taken the van on a run and it hasn't done the issue of when I dip the clutch the revs come tumbling down and van nearly cutting out , also seems steady on tick over , I am not going to count my chickens just yet but will let you know how it goes in case it helps others in the future if they have the same problem
So I have now changed to Bosch Super 4 plugs, Bosch HT leads and a Bosch Coil Pack
Oh Bosch !!
Thanks all for your help
