Crank & Cam sensor surprising results
Postby Piglet » Fri Sep 14, 2018 12:56 pm
My tame mechanic advised me to change both cam & crank sensors as part of tracking down a stubborn glitch.
It didn't fix the problem but,
I was surprised at the improvement made by each sensor in terms of general smooth progressive response.
The van had become a bit rough around the edges, now it drives almost like a new one. Well worth the 10 quid each.
If I could only find the cause of the feking glitch.
Piglet
Re: Crank & Cam sensor surprising results
Postby Kenton » Fri Sep 14, 2018 3:04 pm
Just out of curiosity Piglet, what was your original glitch consisting of? Been interesting reading about the two sensors, as i have just replaced my cam sensor before the injectors, so wondering if i too should also replace the crank sensor??
Cheers as ever.
K
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Piglet » Fri Sep 14, 2018 9:04 pm
Bit hard to describe on paper but only happens when at full temperature, part throttle & light medium load, eg. cruising up gentle incline in 4th.
Best described as 'random hiccup' like my old AP50 moped just starting to suck air.
I can see the fault in For scan as small downward spikes in live data so it's not my imagination, and it hasn't always done it, just started this spring.
Very irritating and reading up I'm not alone but there doesn't seem to be a simple fix.
Piglet
Postby axxeman » Mon Sep 17, 2018 9:27 pm
Piglet wrote:Bit hard to describe on paper but only happens when at full temperature, part throttle & light medium load, eg. cruising up gentle incline in 4th.
As I am unable to locate part numbers, would you be so kind (if you know them), and if they are applicable to 2004 1.8 TDCi 90ps
Thanks.
axxeman
Postby Piglet » Tue Sep 18, 2018 11:09 am
I have no idea if they are the same on a 2004, but here's what I bought:
Crank sensor: eBay item No. https://www.ebay.co.uk/itm/251001099689&seller=&toolid=10018&56628034" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/251001099689 , item is marked with Ford logo
Cam sensor: eBay item No. https://www.ebay.co.uk/itm/263393558719&seller=&toolid=10018&56628034" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/263393558719 , eBay listing states finis 1781666 1219768 1355063 , Again marked Ford, this one came with the Ford box
Piglet
Postby axxeman » Thu Sep 20, 2018 12:03 am
Piglet wrote:I have no idea if they are the same on a 2004, but here's what I bought:
I expect they are for 02 - 13 as there appear to be a lot of parts that stayed the same over the 11 years. It gives me a starting point though, so thank you for that Monsieur Le Piggy.
Footnote - I may have found the air ingress problem causing my spluttering at start-up. Seems that the fuel in pipe that is on the side of the pump is weeping from the banjo bolt connection so, if fuel is slowly oozing out then air must be replacing it in the pipe. Gonna change the copper crush washers and see if that sorts it. If not - it'll be your sensors. If that fails, it'll be a one-way ticket to Switzerland!
Greg
axxeman
Postby Piglet » Thu Sep 20, 2018 12:25 pm
axxeman wrote:If that fails, it'll be a one-way ticket to Switzerland!
For you or the van? :lol:
Piglet
Postby axxeman » Thu Sep 20, 2018 10:23 pm
Haha - brilliant!
axxeman
