I've picked up a replacement set of injectors for my connect as it's got pretty bad diesel knock, its a 110 model so has Siemens injectors that don't need coding.
The injectors were out earlier this year at a local garage so they shouldn't be siezed in the block, hence is changing the injectors a reasonably simply DIY task or should I leave it to a garage? I'm pretty competent mechanically , but I've never touched a diesel system before and don't want to trash my new injectors.
The van has cost me a fortune so far this year and I'd like to save a bit of cash if possible
