Transit connect 2010 trend egr valve issues
Postby Shaunford » Sat Sep 22, 2018 12:23 pm
Hi I recently bought a 2010 transit connect 1.8tdci
It had an egr valve replacement a month ago, it struggles a bit to pull away at times and this week had engine malfunction come up! I took tona garage who plugged it in and said egr fault, reset it and went away for 5 mins then was back, I’ve unolugged the egr and now runs absolutely fine well I think! The tone of engine sounds normal and no faults come up now. I’ve noticed I’m using a small amount of coolant minimal, every time I plug egr valve back in it runs rough, I have taken egr valve motor head off and isn’t clogged and seems to be working and also the other side twists freely. I’m confused and was hoping to seek some impartial advice before taking back to mechanic. When being driven it does feel a little held back. Oil look fine and water looks clean. If anyone could please advise me it would be greatly appreciated
Shaunford
Re: Transit connect 2010 trend egr valve issues
Postby liteace » Sun Sep 23, 2018 4:47 pm
Shaunford wrote:Hi I recently bought a 2010 transit connect 1.8tdci
New genuine part, cheap aftermarket part, used part ?
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby Kenton » Sun Sep 23, 2018 10:19 pm
Did they say what the fault code was? Either fault code or description? Sometimes other fault codes emerge from existing or previous faults.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Shaunford » Mon Sep 24, 2018 4:20 pm
It look like a new part, probably a cheap eBay part. Will it do any damage driving with it unplugged? The van seems to operate normal with it unplugged, no smoking, bad idle or lumpiness. I had engine malfunction warning and also esp warning, no faults at all since being unplugged. Thanks for your responses
Shaunford
