Not sure if I'm missing something but wanted to remove the plastic cambelt cover to look at the source of an oil leak (2012 - 110). Have removed the four fixings but can't seem to get it off, does the engine mount have to be removed to get it off..? Thanks
I believe it does (shocking memory) Easy to remove but be careful if supporting on the sump pan. It's only a bit of pressed tin and if you dent where the pick up sits that can restrict your oil supply, or so I've read.
