Changing PCV 1.8 Petrol Transit Connect
Postby Connect1969 » Mon Sep 24, 2018 9:04 pm
Hi , I want to change the PCV on my connect to see if it helps with fuel efficiency and general better running
I have bought a genuine ford PCV valve and also the crankshaft breather pipe as it looks original so 14 years old and looks a little cracked in places
I took a look and was able to remove the old breather pipe easily but I'm not sure how the PCV is removed ?
I am trying to do this job from the engine bay as I don't have ramps etc, Is this possible or does it need any parts removing to change the PCV that requires a ramp to get underneath ?
Thanks for any advice
Connect1969
Re: Changing PCV 1.8 Petrol Transit Connect
Postby Connect1969 » Thu Sep 27, 2018 4:14 pm
I have now changed the crankshaft breather pipe as I could do this from the engine bay, does anyone know where the PCV valve is ?
I have tried to find out by the Internet but can't find my engine
Does anyone have any ideas ?
Connect1969
Postby Altransit » Thu Sep 27, 2018 8:05 pm
Sorry, but I'm not familiar with the 1.8 petrol engine, (I've only had dealings with the 1.6 zetec) but isn't the PCV located in the top valve cover :?: :idea:
Postby Daz78 » Sat Sep 29, 2018 3:31 pm
hi mate just changed my pcv its on the back of the diesel pump with a black electrical connection on it with two wires going to it it has a cylindrical back piece and a part were u can put a spanner or pair of grips on to to take it out what makes u say its the pcv thanks Darren
Daz78
