Oil Gasket Kit
Oil Gasket Kit
Postby dannysconnect » Sun Nov 04, 2018 6:42 pm
Hi Ladies & Chaps
have various oil leaks on the 2003 TDDI endure engine
I have decided that I want to remove the engine and change every oil seal/gasket this engine has
is there anybody knowledgeable enough to kindly tell me how many and what oil gaskets & seals this van has(more of the less known ones rather than the commonly known ones such valve cover & sump gasket.
Dan
Electrics & Diagnostics
Car Van servicing, diagnostics & Electrical
Cover Berks and Bucks and West London area
dannysconnect
Re: Oil Gasket Kit
Postby blue estate » Sun Nov 04, 2018 6:48 pm
Cam cover , Vac pump , sump ( get new sump as they rust out , but are cheap to buy ) crank seals , oil pump seal , camshaft seal , inner timing chain cover seal , oil cooler seal , turbo oil feed/ return seals
blue estate
Re: Oil Gasket Kit
Postby dannysconnect » Sun Nov 04, 2018 7:06 pm
Top stuff
Many Thanks
dannysconnect
Re: Oil Gasket Kit
Postby dannysconnect » Sun Nov 04, 2018 7:09 pm
Whats your though on replacing the fuel pump chain kit at the same time?
vans done 193k ..... I obviously WON'T hold you responsible... im just looking for an opinion
dannysconnect
Re: Oil Gasket Kit
Postby dannysconnect » Mon Nov 19, 2018 11:31 am
For those who want to know - I replaced the fuel pump timing chain at the same time - It wasn't the easiest of jobs in terms of getting to it - but it is easily achievable with timing tools and patience.
dannysconnect
