steering lock stuck on
Postby alistair roy » Thu Nov 29, 2018 3:03 pm
the steering lock of my connect is stuck on. how do I unlock
alistair roy
Re: steering lock stuck on
Postby dumper » Fri Nov 30, 2018 12:28 am
Have you tried another key it may be worn if that doesn’t work you may have to drill out the security bolts she Curity about sh*t car at cigar Garrity balls if you cannot get it move also if the key turns in the to the position where push the clip in to pull out the lock if it’s that that’s worn I’ve not had a lock off a connect so I’m assuming it’s the same as older transits
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
cron
