Which Connect
Which Connect
Postby xillent » Sun Dec 02, 2018 3:58 pm
Again I'm "considering" a new van (well maybe not brand new but new to me). Looking for a low mileage job if used. I plan to keep her until she dies. Which variant should I
go for. The new facelift model or the previous one? (is the new facelift model worth it).
What about power?
I'd like as many goodies as is worthwhile. Particularly want Cruise control, Air Con and DAB radio.
Any help appreciated.
xillent
Re: Which Connect
Postby mrtn » Sun Dec 02, 2018 6:12 pm
Facelift model with the new auto box and original nose would be a killer.
1.6 Ecoboost A/T LWB '16
mrtn
Re: Which Connect
Postby Pdawber » Fri Dec 07, 2018 11:08 pm
I'd recommend the T230 110ps high roof. You can get a 2011/2012 with low miles (40-50K) for around £6K.
Excellent load capacity and strong enough for long distance driving and carrying. The injectors seem to be a weak spot so check for leaks and rough idling.
I wouldn't get less than a trend trim level if you want to keep it for a while as the basic is really basic.
Pdawber
Re: Which Connect
Postby Piglet » Sat Dec 08, 2018 1:19 pm
2006-2016 I believe is the Siemens Tdci set up which most rate over the earlier Delphi Tdci for reliability.
Piglet
Re: Which Connect
Postby xillent » Wed Dec 12, 2018 10:24 am
Thanks. I've been looking at 120 ps Limited models.
xillent
Re: Which Connect
Postby Mike » Wed Dec 12, 2018 4:21 pm
Without a budget you’re not going to get much help tbh. But as you’ve mentioned the 120ps Limited you’re looking at a late 2016 onward van?
Mike
Wind up merchant!
Re: Which Connect
Postby xillent » Mon Dec 17, 2018 11:03 pm
Yes, I've done a bit more digging. Would prefer a van with some warranty left. Preferably a year
xillent
Re: Which Connect
Postby Mike » Tue Dec 18, 2018 9:37 am
Mike
Wind up merchant!
Re: Which Connect
Postby xillent » Fri Dec 21, 2018 9:51 pm
Thanks Mike
xillent
