non starter
non starter
Postby johnboy231 » Mon Dec 03, 2018 8:22 pm
hi guys
looking for any advice ive fitted a kkda engine out of a focus 06 plate in to my transit connect and cannot get it to start it trys sometimes but will only briefly fire up on easy start.
i swapped oil cooler turbo inlet manifold and the injectors keeping in order from the transit connect engine i didnt swap the pump as i read there not coded.
the van has no fault codes in it does anyone have any ideas
ive also swapped the dual mass from the focus to the solid flywheel with a new clutch
ive also tried 2 different crank sensors
any ideas would be great
thanks john
johnboy231
