Another engine replacement topic
Postby Morris147 » Tue Dec 04, 2018 6:45 pm
Hi all,
The engine in my connect has imploded, from using the search function i have found that i have this engine currently fitted:
1753 cm3 TDCI 2002-> Duratorq-CR RWPF 66/90
Its a 59 plate, 1.8, and i need to get a replacement engine. From what i gather there is loads of engine codes around for the 1.8, Does it matter which replacement i buy?
Many Thanks!
Morris147
Re: Another engine replacement topic
Postby Altransit » Tue Dec 04, 2018 7:10 pm
Postby Morris147 » Tue Dec 04, 2018 7:16 pm
Thanks for the reply, i cant seem to find a solid awnser on the interchangeability.
Morris147
Postby paul2012 » Fri Dec 07, 2018 10:45 pm
Morris147 wrote:Thanks for the reply, i cant seem to find a solid awnser on the interchangeability.
Engines fitted to Connects from 2000-2006 will NOT fit Connects from 2006-2013.
Suitable replacement engine for yours, is one from another connect from 2006 to 2013.
Or one from a Focus mk2 or C-Max with a ENGINE CODE KKDA.
This one here is a direct replacement. :arrow:https://www.ebay.co.uk/itm/2008-Focus-K ... :rk:1:pf:0
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Morris147 » Sat Dec 08, 2018 2:27 pm
Thank you for your reply.
We now have an engine ready to fit, will try and do a build thread.
Morris147
Users browsing this forum: Totty79
