TDDi Timing Belt job ?
Postby aneng » Sun Jan 06, 2019 3:33 pm
Hi.
My wife has a 2003 Connect with the 1.8 TDDi 75ps lump in it. It's coming up to 100k on the clock and I have no idea if it's ever had a new timing belt. We bought the van when it had 80-odd thousand on it. From what I can gather, there are a few different configs of wet/dry belt/chain dual/single (thanks Ford !), and I'm not certain what ours is. I think it's a two-dry-belt system, but I'm far from certain.
I've read up as much as I can find and everything points to buying a set of special tools for the job - flywheel gear locks, alignment tools, special pullers etc etc.
Can anyone give me some idea of how I can be sure which timing setup I've got and also whether I really need all the special tools ? Finally, is it realistically a job worth doing yourself or is it such a pain that it's easier to just get it done professionally ? I've done timing belts before (and rebuilt a head as a result of a snapped one !). I'm technically quite competent and have a decent set of tools, but if I'm only going to save £40 by doing it myself and have to suffer several hours of swearing and skinned-knuckles, I may not bother !
Cheers !
aneng
Re: TDDi Timing Belt job ?
Postby Altransit » Sun Jan 06, 2019 4:37 pm
Yours has an upper belt and a lower chain, so only the belt needs changing at your mileage 8)
Postby aneng » Mon Jan 07, 2019 1:22 am
Cool. Thanks. Can anyone help with the other questions about the tools etc ?
aneng
Postby aneng » Sat Apr 06, 2019 8:53 am
OK, has anyone done a timing belt on a TDDi ?
aneng
Postby Altransit » Sat Apr 06, 2019 2:06 pm
I've not done one myself but I did happen to see one being done, but not from start to finish.
The only special tools that I saw being used, were the timing lock pins, (which were a standard set of Ford type pins from Ebay) and a "hoist" to hold up the engine whilst the O/S mounting was removed. You could replace this with a hefty timber across the struts/inner wings :idea:
HTH
Postby aneng » Tue Apr 16, 2019 10:02 pm
Thanks for that. I can't help wondering why all these over the top locking procedures ? I used to change belts with nothing more than a bottle of Tippex to mark the pulleys. OK, I get that locking the camshaft is a good idea as if you're caught mid-lobe, it could potentially move under pressure from the valve springs, but the crankshaft isn't going to move - unless you're a monumental idiot!
Also - what's the deal with the manual specifying you need to remove the camshaft pulley ? What's that all about ?
aneng
Postby aneng » Fri Apr 19, 2019 9:54 pm
Altransit wrote:Yours has an upper belt and a lower chain, so only the belt needs changing at your mileage 8)
@Altransit - Do you know what the recommended mileage is for the life of the chain please ?
aneng
Postby Jim Archer » Sun Apr 21, 2019 10:39 am
Pinning up is to ensure the pump and cam(s) are timed to the crank correctly. As the belt wears/stretches the timing drifts retarded relative to the crank position.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby aneng » Fri Sep 10, 2021 6:24 pm
Well, I had the belt done last year. Now I can hear the chain clattering on cold starts.
It's done about 120,000 miles now.
It quietens down pretty quickly though. Does anyone know if the Gemini chains have tensioners?
aneng
Postby paul2012 » Tue Sep 28, 2021 7:39 pm
For simple Timing belt replacement - vid here
:arrow: https://www.youtube.com/watch?v=qGoiBPVg5Bo
Same procedure for TDDI :wink:
Lower timing chain. should be replaced at 150,000 miles
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
