P0098 code
P0098 code
Postby f74nk0 » Wed Sep 11, 2019 1:47 pm
Hi I keep getting this code I have change iat sensor
I'm lost now 110ps hope pual the connect man. Can help
Sent from my VOG-L29 using Tapatalk
f74nk0
Re: P0098 code
Postby g-man » Thu Sep 12, 2019 9:18 am
connector or wiring harness?
g-man
Re: P0098 code
Postby f74nk0 » Thu Sep 12, 2019 10:05 am
Hi g mam I have checked wiring and all check out fine it if kkda engine but it was 90 ps but it was knackered so I upgraded
f74nk0
Re: P0098 code
Postby f74nk0 » Thu Sep 12, 2019 12:34 pm
Could it be pcm
f74nk0
Re: P0098 code
Postby f74nk0 » Mon Sep 16, 2019 4:29 pm
Where. Paul when you need him
f74nk0
Re: P0098 code
Postby paul2012 » Mon Sep 16, 2019 5:52 pm
f74nk0 wrote:Where. Paul when you need him
Sorry been very busy doing another conversion for a member on here.
P0098 Intake Air Temperature Sensor 2 Circuit High (Bank 1)
You've fitted a KKDA engine & wanting to run at 110ps :?:
If so don;t use Focus PCM. Used Connects original PCM & update calibration to 110ps.
Also AIT sensor is part of MAF on 110ps - 75ps & 90ps Connects donrt havwe MAF, just a standard AIT sensor :wink:
2004 Jeep Grand Cherokee LTD 2.7
2003 Jaguar X-Type 2.1 V6
2001 BMW Mini Cooper 1.6
2010 Vauxhall Insignia 2.0 CDTI - (CURRENTLY RETROFITTING)
Ford IDS services
SUBCRIBE http://www.youtube.com/c/PaulsTechchannel
paul2012
Re: P0098 code
Postby f74nk0 » Mon Sep 16, 2019 8:07 pm
I have use your
9t11-12a650-dg
f74nk0
Re: P0098 code
Postby f74nk0 » Tue Sep 17, 2019 10:24 am
Is this one right paul
f74nk0
Re: P0098 code
Postby f74nk0 » Tue Sep 17, 2019 5:40 pm
Are you saying I have the wrong maf sensor because I'm using the same one p
f74nk0
Re: P0098 code
Postby f74nk0 » Tue Sep 17, 2019 8:30 pm
I only got 4 wires on mine I need 6
f74nk0
Re: P0098 code
Postby f74nk0 » Tue Sep 17, 2019 9:24 pm
Paul where dose pin 1 and pin 6 go on the pcm plug
f74nk0
Re: P0098 code
Postby f74nk0 » Wed Sep 18, 2019 8:07 pm
All sorted it was changed clooer plug iat
f74nk0
Re: P0098 code
Postby g-man » Thu Sep 19, 2019 8:30 am
clooer plug?
g-man
Re: P0098 code
Postby f74nk0 » Thu Sep 19, 2019 9:41 am
Cooler
f74nk0
Re: P0098 code
Postby f74nk0 » Thu Sep 19, 2019 4:59 pm
Paul I have new codes now
P0113 f1
P0101 f1
Help
f74nk0
croncroncroncron
