steve@hebburn wrote:hi, i have just joined the forum & would like some help with a 2006 tdci 1753 connect 180k. bought last night. when pulling out of a juction the van emitted quite a lot of black smoke, which cleared after 30 or so yards. it then drove fine 5 miles until we reached the a1 motorway ( darlington to tyneside) we got to 55 mph, and the glow plug light started flashing then the engine cut out. a quick off/on of ignition switch & it drove ok , until it happened again. 7 times in total. there was a drop in power/speed. ( no black smoke) we got it home. plugged in a ms300 maxiscan and got PO 251 code. ( injection pump metering control a) would the problem be the fuel injection pump/injectors/sensors ? is this a common fault? also found very dirty air filter.which wont help. i will be changing all filters/oil etc in next few days. thank you for any help/info. steve @hebburn.
