Hi Gents
i have an issue i hope someone can help with.
I have a Transit Connect 2005 1.8 diesel
I had a parasitic drain on the battery when everything was turned off so went about diagnosing it with a multi meter and found that if i pulled fuse 20 from the auxiliary fuse box under the bonnet the battery drain stopped.
The only thing i noticed by pulling this fuse is that the small backlit dashboard clock/mileometer went out (is it normal for this to stay on with the ignition off anyway ?)
So my question is , does anyone know what this fuse protects ? and is it ok to pull it and drive the van
Thanks for any advice
Danny
