Transit connect fuse 20
Postby danny777 » Tue Dec 31, 2019 12:17 pm
Hi Gents
i have an issue i hope someone can help with.
I have a Transit Connect 2005 1.8 diesel
I had a parasitic drain on the battery when everything was turned off so went about diagnosing it with a multi meter and found that if i pulled fuse 20 from the auxiliary fuse box under the bonnet the battery drain stopped.
The only thing i noticed by pulling this fuse is that the small backlit dashboard clock/mileometer went out (is it normal for this to stay on with the ignition off anyway ?)
So my question is , does anyone know what this fuse protects ? and is it ok to pull it and drive the van
Thanks for any advice
Danny
danny777
Re: Transit connect fuse 20
Postby g-man » Tue Dec 31, 2019 2:17 pm
g-man
Postby g-man » Tue Dec 31, 2019 2:25 pm
g-man
Postby danny777 » Sun Jan 05, 2020 8:03 pm
Thanks for the replies
The drain on the battery has stopped once i pulled fuse 20 , so my only question is , does anyone know what this fuse does .
The link above just says PCM , whatever that may be , ECU maybe ?? and does it hurt not to have that fuse "in"
danny777
