Hoping someone can help.
Connect 1.8 TDCi 2003 keeps cutting out, got the codes read and got back -
P0404
P1211
P0251
I’ve changed injectors and fuel filter already.
Any suggestions on where to go next as we’re stuck...
paul2012 wrote:Did you cut open old filter to check for swarf
As Delphi fuel pump do break up internally. Resulting in low fuel rail pressure, metal swarf from pump deposited in fuel filter & fouling injectors at the same time
