Hello, I have just purchased a 2005 Transit connect, the horn does not work, fuse was blown so replaced it. Still didn't work. Swapped a relay and still didn't work. Does anyone have a photo of where horn is located?
I have ordered a Haynes manual but due to Corona it wont be here for a while.
Just behind radiator I can see a bracket with nothing attached and no wiring but there is a broken plastic clip on it. Must of had a horn for the M.o.t.
Just trying to use this lockdown to get things done. There a few things I need to do to it.
Thanks in advance and hope you are all keeping well.
