I hope it is ok to start a fresh topic with a more exact title.
The back and side doors don't open. (well, the back door does, but only from the inside, so be careful how you load )
The side door is missing its lock. so I am guessing it failed or got broken into.
I have no remote fob. Just a key. That key is a copy. The old one was just a smooth bar.
Anyway, the poiint is, that you can't lock the van.
You turn the key, everything locks...... wait a second ....... everything unlocks again.
So, I assume the fact that there is probably no lock on the side at all might not be helping this.
I am trying to work out how to just use the key to lock and unlock and ignore the central lockiing.
My best guess is remove the fuse.
But I can't guess which one.
I looked it up and it says 163. Can't find that. Highest inside goes up to 63.
I think the manual says it should be a triangle on the code sticker in the glove box, but there is none.
Would this work? Or just set of the alarm permanently or something?
Cheers.
