Hi Guys
Need some advice from some knowledgeable folks!
I have a 2016 ford transit connect. Its currently got an issue with some wiring that needs to be replaced but I’m having a hard time finding the wiring part i need.
in the attached photo you will see the repair that’s been done before and needs replacing. its the connector and wiring to the DPF pressure Sensor. I have spoken with ford and they don’t sell just this part and i have spoken to a few garages/ breakers and not having much luck either.
1 - one garage told me that he has a 2016 connect but the ad blue version and this wont fit. is that correct?
2 - does anyone know which wiring loom i need to try find to get what i need? (found an engine wiring look with fuse box for £90)
3 - would parts from a ford focus also work?
if anyone is able to help point me in the right direct to get this fixed ASAP that would be greatly appreciated.
