Hello, I purchased a 2nd hand Connect nine month ago and it has been running fine , now after laying it up for four weeks while waiting for a rear caliper and regularly starting her up just to idle her and keep battery charged I noticed the EML came on on. I have used Forscan and a 'BBfly' OBDII connector to read off the codes.
Can anyone advise me if i need to be concerned or are these issues common and will clear once I drive her in anger once again? or are they worthy of investigating now she's off road?I have a seized rear caliper so have a refurbed one to fit then i'll put it in for mot.I'm gonna drive her up a few hills and get her hot before test and also have some Redex pre mot to go in her.
Van is a 2007 1.8 with 145,000m - i changed the oil and filter along with the transmission oil about 500 mile ago.
I Just wanted to add a bit more infomation without clouding the issues to much ; Going back to when I bought it, I checked it with my basic code reader and it flagged up a issue with the EGR valve even back then but the seller was honest old boy and i had no reason to think it was a problem van. I figured it was because he'd not started it for a couple of months (as he'd bought another larger van) and my limited knowledge was that egr valve gets gummed up if not being driven enough. It also does have to have the key twisted on for some time to get her started sometimes particularly if i haven't started it for a few days,she starts first time but you have to keep the starter motor going for a bit longer than i would think is normal to get her to fire. I had the battery checked at my local halfords and they said it was fine but they said it needed some good long runs. I use a AA solar powered charger on the dash connected to the OBD port when she's parked so some volts get into the battery.
Another problem - It happened to me a while back on the motorway,i was accelerating hard and fast overtaking and then cog light came on and it felt like a loss of power so i pulled over into hard shoulder and turned he engine on and off again. It didn't seem like she had gone into any limp mode just a loss of power so I spoke to AA man he said there was a common problem on the 2007 model where a split in a hose to the turbo could cause this issue. Anyway I was driving her hard up a hill the other day and i thought i'd see if i can repeat the problem so the 'Cog' light came on, took my foot off the accelerator for a second and then the cog light went off, tried it again,hard acceleration up hill produces this Cog light. Seem anytime i put her under real load the cog lisght will flash.
Anyway,I cleared the engine codes a week ago and so these these codes are all from a van which has just been started and left to idle for 20 min every other day.
===PCM DTC P0380-68===
Code: P0380 - Glowplug control circuit
Additional Fault Symptom:
- Invalid Signal
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
Glow Plug Circuit
Short circuit
Open circuit.
This DTC may be caused by :
Possible causes are:
Relay control circuit
Glow plug relay
Malfunctioning EDCM
===END PCM DTC P0380-68===
===PCM DTC P0490-E1===
Code: P0490 - Exhaust Gas Recirculation Control Circuit High
- Signal is Above Maximum Threshold
Status:
- Malfunction Indicator Lamp is On for this DTC
This DTC is set when the following condition occurs.
The EGRV position sensor value is consistently higher than the desired set value.
EGR valve short circuit to battery positive.
Exhaust Gas Recirculation Valve
For further diagnostic information refer to the appropriate section of eTIS.
===END PCM DTC P0490-E1===
===OBDII DTC P0490-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0490-C===
===IC DTC None===
Successful DTC reading, no error codes found
Module: Instrument Cluster
===END IC DTC None===
===CSM DTC None===
Module: Security module
===END CSM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===ECS DTC None===
Module: Electronic Crash Sensor
===END ECS DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
