2016 transit connect U300E:13-2B ignition input on
Postby RGS14 » Wed Feb 24, 2021 11:22 pm
transit connect with flat battery and none start , replaced battery still wouldnt start . cleared trouble codes , still none start . power starter up and it will spin over but not start .
can anybody help ?
RGS14
Re: 2016 transit connect U300E:13-2B ignition input on
Postby Autoginge » Fri Feb 07, 2025 2:13 pm
HI mate, did you ever figure this fault out, it's a bit of a weird one looking at the posts about it. TIA
Autoginge
Postby Autoginge » Sat Feb 08, 2025 11:20 am
RGS14 wrote:transit connect with flat battery and none start , replaced battery still wouldnt start . cleared trouble codes , still none start . power starter up and it will spin over but not start .
can anybody help ?
Morning mate, what was the cure for this after, i have one coming in thats been messed about with by another person not realising the non start was a snapped timing belt but after much messing around and maybe a few voltage spikes from jump starting it is now in the same position yours was, i'm leaning towards replacing the ABS module one data pid is showing 58v module voltage. Thanks.
Autoginge
