All fixed now. Problem was one or more injectors. Fixing just one did not solve the issue, improvement but issue still there. I have replaced all 4 and no longer have the hesitation issue. For anyone reading this with a similar problem, perform a leak off test. Unfortunately I cannot find injector specific leak off data, but I have followed the test as per fordwiki page. My results are far exceeding what is claimed within tolerance over the 5 min period but I know this is not the same injector, nevertheless the van now drives perfectly. Results are with 5ml of each other. Cost me 360 pounds in total, as I needed a new fuel line plus 4 x remanufactured delphi ford retail packaging injectors.
The Test:
The test that I used starts with 2 minutes running at idle followed by:
30 seconds with the accelerator held at 3800 rpm followed by:
30 seconds at idle followed by:
30 seconds at idle.
Delphi state that the fuel temperature should be no less than 50C so hot engine for this test.
https://www.fordwiki.co.uk/index.php?ti ... k-Off_Test Sent from my SM-G930F using Tapatalk
