Hi wonder if anyone can help me please
Not very technically minded I’ve got a battery drain over night to the point after about 6-7 hrs left stood I would need to jump start it again which isn’t very helpful at 3am when u need to go to work.. with out thinking went out and brought new battery and fitted. Next morning flat and needed jumpstart again.
Remember I’m not very technically mind so viewed you tube Videos to learn to test for drains so on
Battery good 12.65v
Alternator charging as should 14.44v
Took the 3rd big 30amp fuse out in fuse box in engine bay and have had no problems what’s so ever nofor the last couple of days starting. Battery holding charge and starting
Today started a little more investigating
Set multi meter on 10amp draw and started pulling fuses starting which one I thought it might be interior lights which never come on when u open the door and only seems to be one setting which I have to physically turn on. When pulled the dome fuse amp draw went down to 0.22 from 0.40 no others fuses made any difference from the internal fuse box.
So started to check the fuse in engine bay.
When I pulled fuse 20 which is a 10amp multi meter showed no drain what so ever . Checking the index it’s says fuse is cluster and engine management. The van starts and everything seems to work other than the red flashing alarm light on the dash. I’m hoping that this is the problem as can live without the alarm. Just worried would this effect anything else
Any insight would be very welcome
Cheers
