MK1 Connect alloy wheel studs
Postby metalworker0 » Sat May 08, 2021 11:30 am
Re- posted as i thought this fairly important and wasn't getting attention where i posted it .
I'm sure studs have to be changed
...I've just bought a 2006 connect with what looks like ford alloys on it...taken them off yesterday...and it seems like the studs are too short ..each nut only held on by about 4 threads ...something not right - this van has had those wheels on for a good few years by the looks of it ..
And am i right in saying: to change the front studs, the hub has to come off ..and that means destroyed wheel bearing - so need new bearings and studs
Rear wheels ..by taking the four bolts out at the rear of the drum.......can the studs be got at ...or do i need to buy new "multi segmented nuts" before I to take them off .
all the best..mark
Re: MK1 Connect alloy wheel studs
Postby metalworker0 » Sat May 08, 2021 12:46 pm
also this
https://www.ebay.co.uk/itm/114768447361 ... SwFBlfglB9
a different wheel nut is available that may overcome this problem , perhaps giving me an extra 3 threads
And why they sell then in 4's ans 16's i don't know , should be 5's or 20's
Postby metalworker0 » Sat May 08, 2021 1:56 pm
ok further investigation .
all nuts are incorrect ..
there was one rogue one on there that was correct
this has a swivelling cone shaped washer, and the threads go all the way to the end of the cone...so has nearly 8 threads that engage.
will try and find a set of them.
Postby blue estate » Sat May 08, 2021 2:07 pm
metalworker0 wrote:ok further investigation .
The nut with the swivel washer is a Ford nut for alloys as it has a tapered end to fit in to the wheel holes
Newer Ford nuts don’t have the swivel washer any more but still fit the same
Also do nuts up to 130Nm
Sent from some where
blue estate
Postby metalworker0 » Sat May 08, 2021 4:08 pm
Thanks , think the main thing is that the threads go all the way to the end of the cone ..those on it now have a recess without threads of about 7mm, so no good at all.
all the best...mark
Postby metalworker0 » Wed May 12, 2021 1:40 pm
BOUGHT THESE,
Cheapest ..I could find that where in the UK ...Chinese seller who has a warehouse here, 2 day postage . delivered this morning, tried them on with a wheel today.
https://www.ebay.co.uk/itm/303718599811
Despite picture showing excess of slop between washer (probably he has chosen one that had a lot of slop to show off the washer in picture)..........they aren't actually like that , They are very well made, quite precise, have no excess of slop and fit perfectly, nice looking chrome, not nickel plated, unless it polished nickel - threads all the way to end of cone - they do the job, well pleased with them, will they rust ..i don't know . i do know that they are a lot better than what was on there before and at an excellent price, great value for money.
So recommended :)
Btw ..right after i left feedback for him he put the price up ..i paid £13.49 delivered
Postby metalworker0 » Sat May 15, 2021 11:02 pm
Moral of this story
Don't use your steel wheel nuts on the alloys, as you only have 3 threads holding them on !
Have a look here and you will see what i mean -- picture 3, Note: no threads in the last bit of the cone
https://www.ebay.co.uk/itm/273322298804&seller=&toolid=10018&92305967" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/273322298804 ... SwucVbMkYH
Make sure and check if you have alloys on, that this dangerous situation isn't happening with your wheels
Postby blue estate » Sun May 16, 2021 10:57 am
metalworker0 wrote:Moral of this story
Linky no worky
blue estate
Postby metalworker0 » Sun May 16, 2021 12:07 pm
put this number into the ebay search
note link is for steel wheel nuts that DO NOT WORK WITH ALLOY WHEELS
