Hello everyone, I have a ford tourneo 1.8tddi 75cv from 2006. I bought it while walking but with a loose piston pin. I brought her home, took the motor out, and made it new. New pistons, new connecting rods, new cylinder head, etc. The truck had no battery for 6 or 7 months. When I assembled everything, it never started. And it didn't start and it didn't start. Tired, I adapted a Bosch VE mechanical pump. It is going well, but not as it should. In the end I got ready to put the VP30 pump on him again. I bought a repaired one, mounted it, and nothing. Does not start. I bought a new CKP crankshaft, and nothing, it won't start. The pump is adapted with forscan.
The only faults that come out are those of the pedal, which I broke to adapt the steel cable, and the intercooler sensor that I have disassembled. but it should still start without throttle, I guess not?
The faults are these:
P1576
P0121
P0221
P0226
P0110
P0515
P1000
Almost all are from the pedal, because it is disconnected, I modified it to make it mechanical. But it is not an impediment to start right?
