So I'm thinking of undersealing my van as about 70% of it is pretty clean underneath. The worst area is from the rear axle backwards. I'm thinking I can remove the rough stuff and underseal over the rest.
However I noticed there's a bit flaking around this red thing (not sure what it's called ). It looks like it's gonna be tricky for my welding guy to do due to the shape and angle and the fact the red thing sits in it.
The guy I had replace my sill done a brilliant job (never seen a better welding job!) but I don't want to bring the van there tomorrow as he'll start poking holes in everything. I may be able to sneak it by an MOT as is but I'm really just looking for some comforting replies and some ideas haha. Ive just bandaged repaired the exhaust, which is why I think that bits badly rusted,due to fumes blasting on it constantly. Also wondering if I'd need to remove my insulation and flooring inside the back of the van for that part to be repaired. I wouldn't think so as it's more a structure than the actual floor metal, but any advice is good.
I've included another picture so you get an idea of the other corroded areas. The middle and front of my van is clean with hardly any corrosion spots!
Any words of advice?
