s2martin wrote:@SandyHenderson - if only I could get away with this I would!
@metalworker0 - thanks for the advice and detailed photos, much appreciated. So I don't think I'll bother with the MOT then until I try and repair it... I was reasonably confident having a go at the sills (even though I'd be learning how to weld at the same time!), but that looks pretty complex, not something you'd recommend for a novice? It's such a shame as the rest of the bodywork on the van is in great condition. Do you know what sort of costs I may be looking at to get it repaired? P.S. your repair job looks mint!
s2martin wrote:My van is currently SORN as I'm converting it into a micro camper, but before I do any work on the conversion I want to ensure it will get through an MOT! I jacked the van up at the weekend on the drivers side rear sill jacking point and the sill partially collapsed
I then went on to read a post on here saying never jack the van here, wish I'd checked before I did! Anyway, it's happened now, but I was hoping to take the van for an MOT next week - does anyone know if this would cause a fail - is it structural? I've attached a photo of the mangled sill.
I imagine if it will fail on this, I'm going to have to get it cut out and new metal welded in, has anyone had this done? Seems that the sills are a common problem on these vans.
paul2012 wrote:MOT Failure. - Prescribed area - Within 30cm of suspension component’s mounting point
