Boghopper wrote:Mine has a row of holes all the way along the outer cills with rubber bungs in them. Every year I go along them all with a undersealing pot and blast oil, diesel and wax oil up in them.
Nice to see it spotted rather than a seam of bird-shite all along the join.
Zinc weld through primer is a new one to me, I shall get a tin of that, sounds handy.
it will be seam welded.
That plate is a backing plate, sill fits over it and butts up against the top half of the old sill.
The mot rules say that the sill has to be continuously seem welded - top sides ..and spot welded at the bottom
You need to put some holes and bungs into the inner sill as well ....because they are not accessible from outer side
those slotted holes you see are at the bottom of the inner sills .........they drain the outer and inner via folds of metal on the inner side ....if you could see them from your holes ..you could put a pipe down them but it would be hard to do .
