Hi,
Sorry if these have been previously answered, however i have searched and cannot find anything so think i may be doing something stupid!!
Problem 1) front drivers side wheel arch was not properly clipped when i got van so bought new pattern yellow clips, however i cannot press arch in far enough to engage new clips without the wing moving in and do not want to bend wing and cant get behind it as inner wheel arch cover is blocking access.....do i remove this first ?
Problem 2) fuel tanks seems to leak occasionally when fuel level is high.....is there a common point that leaks as it not damaged on the bottom , i am currently awaiting to run lower on fuel before i get under there in case i have to remove tank but thought i would ask in case there are common things i need to replace
Problem 3) how hard is it to access the lower rear engine mount as it has been an advisory on the van for the last 3 years mot history ?
many thanks for any help offered as i have been working through the many issues this van had when i bought her and she is now looking and driving lovely........!
Pugo
