metalworker0 wrote:just realised after a post just made that there is a carrier bearing on the drivers side ..it could well be this that is causing problems ..sorry new to transits ..did not even know it had one ..my info was based on other cars that did not have one of these .
it's a £20 part
YRob wrote:Thanks Mark.
Yes, I know about the carrier bearing but don't think it's that.
I now have a slight clunk in the steering which could be either associated wear or the actual problem becoming clearer. Will check the inner tie rods first.
Do you know if you can replace the inner tie rods without removing the control arm, or would you need one of those special tools?
but ..cant think why you are blaming these, as you said it was road speed related ..therefor it is a rotating part that is to blame.
