Hi all,
I recently purchased a 14 plate transit connect 200, 41k miles, and am having a couple of issues.
#1 I'm curious as I have nothing to compare it to- Is this the standard liner for the rear wheel arch or is there somthing missing?
https://youtu.be/h1U7hB-LH9Q
https://youtu.be/dyibwVwgNL4
https://youtu.be/nKUYXa57cJ0
#2 The vehicle keeps going into limp mode- no particular scenario causes it, it's happened at 30mph and national, loaded and unloaded. Restarting the engine clears the fault.
I had the codes read the first time it happened and it came up with;
P2599-00 Turbo boost position sensor stuck high.
P1303-78 EGR calibration fault.
Returned it to the dealer I purchased it from (under warranty) and they regened the DPF and gave it back- It ran MUCH better for 1000 miles or so and then the engine pitch changed and the fault came back.
Returned again to the dealer and this time they said there was no fault recorded, which is very strange.
It's still not running well- sounds 'Gassy' and I'm just waiting for it to go again
Any advice?
