04 transit connect wiper issue
Postby Jeffw » Wed Sep 22, 2021 9:50 pm
Hi all
My 04 LWB connect van has a strange problem
When the ignition key is put in on the 2nd position , the wipers go 4 times , then everything works fine.
If I have a short journey and start it again , as well as the 4 wiper cycles there is a few times an Audiable beep beep beep beep ? But as said before - the van starts and drives fine.
Also at dark time I note that the two oblong shape lights are lit all night long .
After 2 to 3 days of non use of the van , the batter drains .
So far I’ve
Had the BCM module replaced at a garage
Had a new wiper switch fitted
Paid a garage in time trying to solve the problem.
Yet the same thing happens every time !!
Any ideas
Thanks Jeff
Jeffw
Re: 04 transit connect wiper issue
Postby 19eddie82 » Mon Oct 04, 2021 9:21 pm
I think you should be having the battery checked, probably find that it’s on its way out and that’s what sets the wipers off.
19eddie82
