Hi,
i was a idiot and removed my pcm from my 2003 1.8 tdci connect without disconnecting the battery.
Now the car is not starting, when i turn on ignition the mileage only shows ----- and the immobilizer light is not flashing at all. Its off all the time. When trying to start nothing happens.
Forscan can not find connection to ic and pcm.
I checked all fuses and relais and the pcm gets 12v from 3 pins so should be fine i guess.
Have i killed my ic or pcm?
Is there any whay to check if the problem is down tonthe pcm or ic?
